1 - 4 of 4 Posts
94 Civic Ex Sedan
1994 civic
  • When my headlight control switch (next to the steering wheel) is turned to the setting right before the "headlights on": left front light works right light does not
  • When I press my hazards switch, the right front one blinks but the left doesn't.
I have been looking in my factory service manual but not even sure exactly where to start.
Figured I'd post here. Thanks in advance if anyone has any input
clean the gang grounds by each headlight to start with.
I can't remember if the bulbs were dual filament or not.
Like transzex said clean and check the grounds. Could also be a shorts so while your checking ground check the rest of the wires.
1 - 4 of 4 Posts
