ej2
ok well this morning I started my car, started just fine, went to work, got off work, drove home, just fine. then I got home and shut it off came inside for about 20 minutes and came back out and started it, I noticed that the idle was bouncing alot, rev up then die, rev up then die, didnt think to much of it cause the idle is funky...well I started driving and couldnt get it past 1700 rpms, so I stopped by my buddies and let it cool down and it ran just fine couple hours later but then got down the road and did the same thing, I checked the vac's, I didnt see anything unplugged, could it be a injector clogged or could it be that the ECU is a PR4 with a D15b2 w/ MPFI? no CEL's until I shut it off which was a code 7 I think which is the TPS
ej2
actually its wierd, I started up this morning and everything was just fine, Im guessing it had to do with the fuel that I put in it, had some kinda addictive, dont remember what it was but now my tank is bout empty and seems to be just fine...
Just keep an eye on it then, MAP sensors can be intermittent as my friend found out the other day so might be worth getting a spare when your down your local scrappy next time
Chris ;)
