1 - 2 of 2 Posts
hey guys n00b question.. :shocked: .. im getting this problem about heat @ my d15 engine (sedan 94) i need to find out where the hell is the water pump at this car :confused: if you can post some pics better at.
This is a D16 but it's in the same spot as your D15.
It's recommended to change the timing belt and water pump every 100K miles.
Overheating can be caused by a lot of things from bad radiator fluid to bad cap, radiator may need a flush, electric fan may be out... lotsa causes...
1 - 2 of 2 Posts
