Hello!!
I bought:
-Belt tensioner and timming belt from D16A1 89 integra, its a 124 teeth 24mm.
-Water pump for 88-91 crx si, i think for D16A6
-Oil pump for 88-91 crx si, D16A6 too.
Some people tell me that the oil pump the D16Z6 is not recommended because is high presure, and my engine is low presure oil pump.
Are right the parts??
Thanks!!!
93 integra ls b18c
there are alot of forums about parts u can and cant use zcr forums is where i went to find what i could use from the integra and what i could use from other d series motors check it out
Then water pump and oil pump is right?
My engine is european crx, they come stock with Dohc ZC renamed to D16A9, with 4-2-1 stock header pm7 ecu and other things, agressive timing, 130HP.
They are 2-3Gen Dohc Zc.
I think that the timing belt is right because, i bought already one kit of D16A1 89' integra and i'm running with this kit with no problem.
Is 124 Teeth 24mm belt. Not 129 teeth
Thanks!!
