1 - 7 of 7 Posts
I need some new springs for my wastegate. I'm not sure on which springs to get? I'm planning on running about 15psi (goal: 200-250whp) when the block is built. any help is appreciated. I'm a little confuse about this, I tried searching but it didn't help.
Would tial 38m wastegate spring fit into the turbosmart 38mm wastegate? (If that is what you are asking.) I'm assuming it should fit since they are both 38mm wastegate.
1 - 7 of 7 Posts
