1 - 19 of 19 Posts
the fire ring missing.
Spring broken.
No spring at all
a ripped diaphragm would not cause this problem on an external gate because it still had the spring pressing down on the valve. It only opens when boost psi hits the diaphragm and pushes up against the spring rate.
Sometimes the springs that come in them are too light, and they will stick opened a bit. This is easily fixed with a genuine tial spring.
wheres my money man!!
I have tried a blue silver and black spring
this is what im working with. i dont see this firering
You need the part i posted. It seals the valve when its bolted to the manifold.
Ebay 38mm or 35mm wategate fire ring. depends on your wg size
check your manifold, it might be still on that. if not any 38mm valve seat will work
Not true. Least with my Ebay wg. Bought a tial 38mm and didn't Work in Ebay gate.
1 - 19 of 19 Posts
