1 - 3 of 3 Posts
formerly Kit88
Guys, need to know how to install the fire ring on my tial wastegate.
Also need to know if I just want to run 7psi on my turbo (this is the spring rate on my tial wastegate) just need to hook the bottom inlet on the wg with the inlet on the compressor housing???
Guys, need to know how to install the fire ring on my tial wastegate. I just tab my in and let the rest seat itself once it's bolt it on.
Also need to know if I just want to run 7psi on my turbo (this is the spring rate on my tial wastegate) just need to hook the bottom inlet on the wg with the inlet on the compressor housing??? Yes.
formerly Kit88
as always, you are fast !!!
Thanks Bro
1 - 3 of 3 Posts
