Hey guys.
Currently will be aiming for 25 - 30 psi on my built D16z6. Currently running a Garrett Gt3040 Turbo with a tial 38mm External wastegate. Running a hondata S300 with the Hondata boost solenoid. Is there a good 'rule of thumb' ratio that should be used or not exceeded when boosting to levels this high? I have herd myths that you cannot go double the wastegate spring with the solenoid and have steady boost levels. Eg 10psi Spring with the EBC solenoid = 20psi max.
Therefor would i be better useing a 15psi spring and useing the EBC to take it out to 25 - 30 psi ? Also when useing a high spring psi will that effect the way / rate a engine will build and/or maintain boost pressure etc ?
Thanks guys
Lyle
Thanks guys
Lyle
