1 - 20 of 41 Posts
Lifes short, drive fast!
wut do you really want to know? people do both. it will be much quieter if you run it in the d.p.
i ran mine straight down
R2.....Zap Balls
94 Ex coupe
:werd:, me too. Open dump sounds so sexy under boost :D.
Honda Civic
ya the guys who did my oil return. told me to run it to the down pipe... i think that more work for me and more money 4 him... so im going with the open down pipe.
Honda Civic Si-T
be more specific about the question its a 50/50 question/answer people do both, traditional way is to return, but alot run open external dump tubes (aka screamer pipe)
cars are less noisey under boost with return and alot more noisey with open dump,
i run external dump and its abit noise but not too bad with only 8psi, if i run 15psi its even louder
i did mine back into the DP
stealth FTW plus i dont like exhaust dumping onto anything and making it black.
Acura TL-P
hmm ya the guys who did my oil return, said you could hurt the waste gate piston because of no back pressure. whats why i ask the question.
Open dump all day, everyday. The only reason I've ever recirculated a dump was for the quietness at a customer request.
listen to this man lol
not bad at all
here is mine
anyone have some pictures of an open downpipe? That is how I was planning to run mine but I don't want my block covered in soot!
well if you run it close to the exhaust and under the engine you will be fine
My 91 Crx Hf
97 Civic Coupe
Yeah mine will be running basically right beside the downpipe, and stops like at like the oil pan gasket and just shoots right down. I might just weld it up to the downpipe since it is right beside it, or see how I like it with the open dumptube. haha I am not sure but.. /threadjack
1 - 20 of 41 Posts
