1 - 11 of 11 Posts
well my mechanic wants 75 bucks labor to install my 255 walbro, I know it cant be that hard.... now I know you have to take out your back seat( already done) and you remove that plate thing then what???? could I do this myself?.....can anyone give me some tisp???? I would GREATLY appreciate it!! Thanks Paul
^^^^^ wrong... i'll help ya out... first take your gas cap off, let out pressure. remove plate. disconnect connecter. remove the two fuel lines.. have shop rags it maybe leak a little fuel.. slowly remove the whole fuel pump.. remove the stock fuel pump from bracket, a clip holds the pump on.. rmove the sock on the bottem of fuel pump and put on walbro... place walbro on bracket, might have to bend the bottem of braket a little... and put in tank connect lines and connector.. bolt all back put gas cap on... then cycle key to on then off 5 times you'll hear the pump whine.. make sure to charge the lines by turnning key to on postion, but not running.. at least 5 times. then fire up and good to go... very easy only basic mech. knowleadge needed.. any problems let me know.
D
Dude its so easy my wife did mine while I was putting in the turbo setup LOL Dont waste the $75 you can do it man!
you guys rock!!! Thanks for the info!!!!!!!!
i dont let mechanics touch my car lol i dont trust anyones work but my own so if somthing breaks im the one to blame lol
good luck with the feul pump man
Shoot me!
2000 hatchback
Couldnt have said it any better i did this install on a 2000 hatch very simple believe me you can do it.
It actually takes longer to take out your rear seat and thats like 2 clips.
Actually, the first thing you need to do is disconnect the battery. The rest sounds right on the money.
WERD!
Yeah, FUCK! your mechanic! I wonder what else he's ripped you on......92+ it only takes literally 5 mins. .
Yeah, like d16a6 power said, try doing it on a 88-91, shit takes forever. :mad:
3100 posts and you can't remove a fuel pump........... J/K
1 - 11 of 11 Posts
