1 - 3 of 3 Posts
Civic EK3
Hi
i have read all thread about wiring vtec an i know that a4 and d6 slot i must wire, but i have only 1 wire from the vtec not 2 wire. How i can wiring it that i have vtec. I have done a minime with y8 parts and i have a p28 ecu with d16y8 map.
You should have one wire off of your vtec solenoid and 2 wires off your vtec oil pressure switch. Off the top of my head i think a4 is your vtec solenoid wire and d6 is your vtec oil pressure wire, the other wire from the pressure switch is a ground and just find a stop on the engine to ground it to or the frame. Hope this helps!
1 - 3 of 3 Posts
