1 - 4 of 4 Posts
Can somebody post a picture of the two pin connector that plugs into the vtec solenoid? My pins came out of my connector so I don't know which wire goes where into the plug.
just guess, based on the way there coming out of the wiring harness....
your ethier going to throw a cel or not. no biggy, if you throw a cel switch it.
Thanks. That's what I was gonna do. Just wanted to know for sure.
That two-pin connector is for oil pressure switch. It doesn't matter which way you connect then, it just connects those pins together when there's enough oil pressure.
1 - 4 of 4 Posts
