Just wired up vtec. I have a 92 so its prewired to the cannon plug. I connected the green/yellow from the vs to the orange/blue.
Im getting a code 21 so I looked it up and found out it was the vs so i googled and there were people talking about "make sure both wires for vtec are connected" but I only have one.
So am I missing something or is it just one wire and my vs is bad?
to make it a little easier for myself i wen to a junkyard and snipped the clip for the oil pressure switch so it would be easier to work with, you dont necessarily need the clip but it helps alot.
the engine is a jdm d15b, there is no blue/black on the vs. There is only one plug on the vs and its green/yellow.
The japanese d15b did not come with an oil pressure switch. Didn't know that.
You just simply bypass the switch on the ecu. By soldering 2 wires together for the solenoid. You could also use a gator clip.
Wire A4 (green/yellow) to d6 (light blue)
then run a wire from those 2 up to the wire coming off of your vtec solenoid
this is how it is wired up in my car and it works.
I am running a CX wiring harness.
I would recommend that if you are using a VX harness to go ahead and buy a vtec solenoid with 3 wires and just plug it in.
That worked thanks. Only cleared the ecu and no more codes after that.
Only thing I'm worried about is I hooked up a temp vtec light and it doesnt lite up. Does the car engage vtec when its not moving or do I have to be driving?
you have to be driving to engage vtec.
