1 - 20 of 20 Posts
swapped a d15b7 in my ek hatch. Running a p06 with a conversion harness. Runs but is misfiring bad especially in the lower RPMs.
When I did the swap I used my obd2 dizzy off my y8 head becuz of the connector issue. (motor was blown) Would this cause the misfire? do i need different spark plugs with the different dizzy? i chcked for vacuum leaks, none i have a cel so ill pull the codes and post later.thanks
i have the d15 dizzy so i might just splice it in but i wana be sure it will fix it before hacking up my harness
why not just swap the head onto the b7? using the y8 intake? pretty sure youre meant to use the b7 dizzy to make it run right
Reactions: BogusSVO
you failed to check ignition timing. the OBD2 distributor is not a direct swap as far as timing. you WILL need to swing it one way or the other to get the timing light to match the timing marks on the crank pulley.
Sometimes its only needing a slight turn, sometimes its nearly maxed out in the slots. In rare cases you will need to hog out the mounting holes slightly to get timing correct.
and just to piss us off, there are also rare times it sits spot on centered and works perfectly.
so your saying i need to unbolt the dizzy and do what? rotate its location? or the little spingle thing that goes in the head.? lol sorry my first car so go easy on me
did you check timing? if youre using an odb1 engine, you should use the odb1 distributor. Im sure if you google it, youll find out what to use.
DIY Guru
96 Ranger-stock
You need to get a timing light.
Open hood
Clean timing marks on balancer and front cover
Hook up timing light according to owners manual
start car
Loosen dizzy hold down bolts
One had hold timing light, other hand turn dizzy to FSM ignition spec.
With out moving dizzy, tighten hold down bolts
Remove timing light
Shut hood
have a nice day
the mounting bolts for the distributor need to stay put. you loosen them.
Bogus nailed it.
I assumed you had a little background if you had an OBD1 engine and conversion harness and all that.
timing should ALWAYS be checked when the distributor, head, block, or crank pulley is touched in any way.
1 degree off can lead to noticable performance difference if on the right component.
This also means once you figure out the issue, you learn a bit more about your car.
EDIT to adjust timing for the ecu to actually save it, you need to jump the service connector.
have the car warmed up FULLY before adjusting timing.
DIY Guru
96 Ranger-stock
Matt, I thought there would be a SPout to be dealt with and someone would speak up about it.
So if you or someone else, would like to go ahead and lay out step by step where it is, and just how it is jumped at the service connecter.
We will have that question dealt with.
Spout is the Ford term to disable the ECU from the Dizzy when setting base timing. Its what I know, Just a little plug to pull.
im just gonna wire the d15 dizzy i dnt have a timing light or anything like that. thanks aain for the help boys !
DIY Guru
96 Ranger-stock
Timing lights can be had new for less than $20 bux
After wrenches and sockets, a timing light should be the next tool you get, then a voltmeter
lol I dont own a timing light myself, I just have over a dozen to choose from depending on who I call or viist lol
Since reading and understanding fails you I'll just make it simple. You will have the same problem you have now. Taking out the dizzy the timing will be off and you will need to set it to make it right. A timing gun/light is needed to do this
Unless you are a miracle worker, a distributor, once unbolted, will need the timing adjusted once installed. Unless it is the same exact setup and you marked where it was.
honda made the mounting points adjustable because of the way the sensors are inside the distributor. they can shift over time a tiny bit, but the distributor is not cast with 100% accuracy of parts palcement.
I advise you to skip wiring in a OBD1 distributor. just depin the plugs if you need to swap distributor generations.
Injector timing snail is 180 out in a non vtec obd1 dizzys. It isnt a huge deal if everything else is correct, and it makes the most difference at idle.
Theres nothing Vtec about a dizzy.
You dont really need a timing light for jack shit, ecpecially sing 90% of people dont know what it represents. The engine should run decent over the whole range of adjustment or else something else is wrong.
Discussion Starter #19
really? this motor ran mint before i swapped it into my obd2 hatch now its misfiring badd
Sloppy Jalopy
don't be a baby about cutting into one wire ,put in the b7 dizzy :bandito:
1 - 20 of 20 Posts
