1 - 3 of 3 Posts
i shoot stuff
this is my first time wiring up vtec and i have run into a few problems
does it matter which wire is ground when wiring the vtec oil preasure sensor
i aslo made a vtec light and it is not coming on so i am wondering if i have no vtec b/c i screwed something up
i have a 94 cx w/ d15b on a p08
alright man the black wire coming off the vtec oil pressure sensor is ground the blue and black wire run to d6 in the ecu and the green/yellow wire off the solenoid run to a4 in the ecu. now this is for a d16z6 so i dont know if the wire colors are the same or not.
also the vtec light should be run off the ground and then the blue/black wire not the green yellow wire which i did the first time i tried to wire it and it did not work. then i switched and it works fine.
also if you go to the top of the page and hit the search button and type in vtec wiring you will find tons of info.....
good luck bro
i shoot stuff
thanks a lot but the colors dont help b/c i reused my old wire harness and rann the wires separately
is the black wire the wire that is closest to the clip of the sensor
1 - 3 of 3 Posts
