1 - 4 of 4 Posts
88 ED6
I pulled a VSS off of a 93 Civic CX and tried to put it in my ZC transmission. It seems that the VSS won't fit in there because the ears hit this mount or whatever it is. Has anyone encountered this problem? I'm thinking about cutting off one of the ears so it will fit.
pics please
I test fitted a VSS in a CRX tranny, it even used the same bolt hole as the clip for the speedo drive.
88 ED6
Well I already cut the ear off; i had to grind some of the VSS too because I cut the ear on the wrong side.
88 ED6
Sorry for the bad quality.
this is how I wanted it but as you can see I cut the wrong ear off:
This is how it is right now:
I had to grind a little bit so itll fit over that mount area or whatever that section was used for.
1 - 4 of 4 Posts
