1 - 13 of 13 Posts
89 crx
long story short is the transmission fill plug is rounded off and not even the "easy out" for messed up bolt head will do the trick. someone suggested i just remove the VSS and fill the transmission though the VSS hole. from diagrams it looks like i wont be able to remove the VSS from the outside of the transmission. so im going to have it towed to a shop and have them torch off the fill plug bolt. anyone have any thoughts? thanks for your input!
~Rusty
Your VSS should have 3 bolts on it. I believe 2 that hold the sensor/connector to the gear shaft, and 1 that holds it to the trans. Remove the one that holds it to the trans and it will lift right out.
Fill the trans with a funnel with a hose on it, replace the sensor, and do burnouts.
89 crx
its 89 honda crx dx manual transmission all i see is a cable, that i removed from a tube, looks like this
del Sol si '94
Remove intake air tube, remove 1 10mm bolt from vss, pull it out, stick in long transmission funnel and dump in 2 quarts. Rock on.
Or fill from the vent tube?
I have one question. Why was the fill bolt so tight?
List the year of the Mopar tranny please.
89 crx
when i got the car the bolt was rounded off some what. so i would just use vise grips and a hammer to remove and install it. now its stuck and i have learned my lesson. XD
08 H-D Ultra Classic
Weld a nut on top of it and wrench it off
You get it off this time, replace it they are only $2 at the dealer.
You can fill from the vent tube, the VSS or reverse switch.
1 - 13 of 13 Posts
