1 - 9 of 9 Posts
i have turboed zc bottom end that was blown due to inproper tuning. it has eagle rods with wiesco pistons. some 75.5 mm vitaras will work with the same eagle rods correct?
Thats All Depending On The Damage That Occured.... Your Piston Walls Could Be Extremely Scared Or Lightly It All Depends..... You Wont Know Until You Take It Apart.
See above...
To simply answer your question...yes. But there's alot of factors. So why spend the $400/500 for awesome pistons and not tune the setup correctly?
its stock now. i am going to get it bored 20 over, hence the 75.5's. i was not the one that did not have it tuned properly. once the build is done it will be tuned.
racist-bigot-sexist-homophob
SOHC or DOHC? Vitaras in a dohc zc will net a SUPER LOW c/r.
1 - 9 of 9 Posts
