1 - 11 of 11 Posts
yes on the comp calc it comes up around 7.9:1 or something like that. theres a guy on hmt with a z6 block y7 head with vitaras claiming even with his low comp it feels just the same as stock.
sorry for the lack of info.
you can wait for those custom length i-beams from fjt as well. or have your head or block decked also. i think you can also just chuck a y8 head into the mix and up the comp a fair amount.
or is the idea to stay away from vtec?
yeah i have zc nonvtec with vitaras... my tiny t3 spools up very quickly! it runs like a champ and it's untuned! the problem with the low comp is that you don't get good throttle response or the low end not that good... but top end it pretty good..
formerly allnaturalrex
mill the head if your worried or deck the block your choice.
^^diddo. you can play around with the compression calculator to see how much you want to shave off, get ahold of a local machine shop. ive had heads planed down for less than $30. plus you got a nice new sealing surface! :)
1 - 11 of 11 Posts
