1 - 2 of 2 Posts
i've heard good things about the vitara's and was thinking about getting these. I got in touch with someone who sells them and he said these pistons wouldn't work in the d15z6 because of the stroke (84,5mm) is to short.
He said its not going to work with that block because of the length of the rod..The piston would come up past the sleeve top.. And i would need to get a d15 block with a 90mm stroke or a d16 block
Can someone verify this? And is there a way to make this work?
i was thinking about shorter rods (if available) or a thicker head gasket, would any of this work?
Thanks
1 - 2 of 2 Posts
