1 - 10 of 10 Posts
G
Where do I get 75.5mm Vitara pistons for cheap?
What has to be done to my block to support these pistons?
Is there a specific rod length that I have to use with these pistons?
What compression ratio will these pistons create?
How much power/boost can the pistons withstand?
TIA
GDubb
Honda Civic
1. you can look all over the internet
(or someone may provide a specific website...(I recommend ebay...lol)
2. You really just need to have the block bored over .020 thousandths thats 75.5mm
3. Aftermarket rods will work well....eagles...tunertoyz....ext..
4. depends on what pistons you get
5. it all depends on tuning
1999 civic Hatchback
The only way to get 75.5mm is to get the OEM ones straight from the dealer...That would throw away the cheapness of this build since you would pay over 200 for just the pistons..no rings.
Lifetime Awesome Member
'89 CRX HF
i sold my .020 over pistons for $130 shipped with rings...brand new!
but you really have to search to find a deal like that, they dont come around very often
Out here is +/- 55 bucks each piston(standard) from the dealer..That makes it 220 just for a set of 4..No rings
same, heat treated(if theyre the same brand i work with)..the oversized are .04 which is 76mm
1 - 10 of 10 Posts
