1 - 13 of 13 Posts
does anyone think this sounds more like a higher pitched knocking? or is this wat a normal vitara sounds like? its all perfectly audible from the inside of the car as well.
www.rifftrax.com
1996 Civic Ex Sedan
doesn't sound abnormal to me. it would help if you had revved the engine a little in the video.
Friend of the D
Agreed.... is the engine warm there? I always think the d-series sounds like a sewing machine at idle anyways. Your's does. Are you worried because you used 75mm pistons with out an overbore?
1993 Cobra
What are you smuggling a desiel in there somewhere!?! Sounds like a valve adjustment is needed.
all my valves were adjusted. it has about 120 miles on it.
well... considering the original walls still had the crosshatches. i didnt take much off with the hone.
1 - 13 of 13 Posts
