1 - 7 of 7 Posts
1991 Honda Civic SI
Vitaras,Water Pump,Timing Belt,Bearings,Gasket Set- $320.00 through FJT
Tuner Toy Rods with A.R.P rod bolts-$235.00
A.R.P Head Studs-$90.00
Walboro 190lph fuel pump-$100.00
DSM Injectors-$65.00
obd1 Dizzy- $??.??
Socketed and Chipped P06 ECU-$???.??
LSD Clutch with Street Disk-$300.00
Wires,Cap,Rotor Button,Plugs-$100.00
List of parts coming off old engine into new rebuilt motor
-Crankshaft
-Oil Pan
-Oil Pump
-Wiring Harness
-Intake Manifold
-Throttle Body
-Head getting rebuilt with a 3 angle and P.N.P job, Camshaft is being debated.
-Valve Cover
-Alternator
-Starter
-A6 Transmission
-Flywheel ( resurfaced)
racist-bigot-sexist-homophob
Just say no to Nippon vitaras...the ones you want are YCP vitaras.
im slow whats the difference, not that i will ever get any
1991 Honda Civic SI
well shit the site that was down, conveniently got removed from my bookmarks,I will finish tomorrow made this thread as another reference point if any needed a "how much can I get boosted for" questions.
screw nippon vitaras just cause there made in japan supposedly doesnt mean there the right ones. get the ycp vitaras from fjt. other than that your cool.
see above
your gonna need a higher rated clutch, 210ft lb. if your building that block i assume that your gonna make more than 210 ft lb's of tq.
and as far as that cam gear?. i dont see a need , stock cam phasing is fine where it is IYAM, (if you ask me.)
i was wondering, why dont you just contact fjt for all your needs, he sells a bearing piston gasket combo pack. could save you some troubles. getting it all at once.
:TU:
good prices.i would say
1 - 7 of 7 Posts
