1995 EJ1 EX
Just finished my own swap and found very few highly detailed guides on the wiring needed to bring a conversion close to stock. That being said, I went through the factory diagrams and whipped this baby up after doing it on my own car. Works great. Hope this helps some folks out there.( if ANYONE is still doing EG swaps)
note: also covers the wiring for the cruise ctrl switch
Honda Civic
Very awesome. Bone and I were noticing that you could plug the tcc connector into the reverse light connector and find the pinnout for a much cleaner install. Very nice work!
ministry of mayhem!
93 honda integra
EG8
That is exactly what i did for mine also! Good job finding the diagram.
1995 EJ1 EX
Thanks, although I didnt find it, rather...I made it. In any case, you might notice it says to intercept the IG2 signal...it would probably suit you guys better to intercept the ST signal wire, as was originally intended from factory, I made that change to my harness a while back. Works better that way.
