1 - 10 of 10 Posts
91 civic hb
when i take a turn to the left and the body rolls to the right or hit a dip on my right tire theres a bad vibration not just vibration but a bad feeling its hard to explain i just got the wheel bearing replaced so its not that could it be me axel at all it doesnt click or anything when i turn and my boots arent torn so what could it be
wheel is out of balance, rotor is warped, suspension coponet could be shot
it vibrates when you turn? could be a steering arm, ball joint,
anybody else feel free to chime in
See above...
Yes, first check the obvious things...lug nuts, wheels weights are still on the rim, axle nut tight, nuts/bolts all tight under that sides. if all of that passes your check, then start to look at replacing things. Tie rod is my first guess of what might need to be replaced.
1 - 10 of 10 Posts
