We have always been a distributor of vibrant products, but we are going to be passing a long some deals to d series members. Vibrant is well known for a lot of things but right now there flat black mufflers are really getting some attention from people. They are perfect for turbo setups and produce a nice deep throaty sound. We will be updating a few other items in the days to come, stay tune for some pics. :yes:
Items we will be posting up will include, mufflers, custom fabrication parts (I.E mandrel bends, 02 bungs... ) , catch cans, resonators...
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
I, for one, would like to see these products. Planning a custom exhaust build soon.
First up STREETPOWER FLAT BLACK Oval Muffler
- Fly below the radar with a Vibrant STREETPOWER Flat Black Muffler. It's a must for any true "Sleeper" car.
- 100% T304 Stainless Steel Construction with a high temperature Flat Black coating to help avoid unwanted attention
- Feature Vibrant's "True Straight Through" perforated internals for unrestricted flow and maximum horsepower.
- These mufflers are densely packed with our premium multi-layered sound absorption materials, helping produce a low, deep exhaust tone.
Next up
Warranty: Five Year Limited Warranty
Notes: - Designed to dampen exhaust noise without restricting exhaust flow.
- Feature Vibrant's "True Straight Through" perforated core, surrounded by our premium sound absorption materials.
Resonator Specs
Inlet Diameter: 2.25"
Outlet Diameter: 2.25"
Resonator Size: 3.5" Round Body, 9.5" Long
Overall Length: 12"
Looking to build custom exhaust setups, well you're gonna need mandrel bends
These come in all sorts of shapes and sizes
- These incredibly tight bends are ideal for the most difficult fabrication projects.
- 16 gauge (0.065") thickness
- U Bend Center Line Radius: 1.5"
- Leg Length: 4"
U-J Bend Specifications
Tube Diameter - All sizes, contact us for sizing price
U-Bend Centerline Radius - 3"
Leg Length A - 5"
Leg Length B - 9"
Leg Length C - 12"
Tube Thickness - 0.065" (1.65mm)
- Vibrant's unique U-J Mandrel Bent Tubing combines a 180 degree bend and a 45 degree bend into one integral unit to give fabricators the ability to get up to 3 seperate bends and a substantial straight length from each piece.
- Ideal for building custom exhaust systems, headers, downpipes, intercooler piping, etc....
- T304 Stainless Steel is a non-magnetic alloy that possesses very high chromium and nickel content, making it much more capable of withstanding acidic, high heat and corrosive conditions than regular (mild) steel.
Need flanges for those setups, don't go shopping around, by it all from us, make it easy on yourself.
Flange Dimensions
Overall Flange Width - 4.9" (125mm)
Overall Flange Height - 3" (76mm)
Bolt Circle Width - 3.5" (89mm)
Thickness - 3/8" (10mm)
We also sell a cheaper alternative to these, there not stainnless like vibrants but they do work just as good.
Need some bungs.... yes I said bungs.
Notes: - M18 x 1.5 Thread. Accepts all standard O2 sensors.
- Sold in Bulk Packs of 5 bungs per bag.
Looking for a catch can as well, yep vibrant has you covered, either in polished or flat black. Wel also have an fitting sizes you need and stainless hose.
Notes: - Vibrant's new universal Aluminum Catch Can is the first to offer a "modular" design. The length of this catch can is fully adjustable to accomodate the available space in your engine bay. The can measures 3" O.D. x 10" Long but can be cut down to whatever length you wish.
- End caps are pressure fit to the catch can, allowing them to be removed so you can clean the inside of the can. The end caps come with 2 Viton O-Rings for a leak free seal.
- Suitable for various applications: Oil, Fluid (i.e. Coolant) and Vacuum.
- 16 Available ports, tapped for 1/4" NPT Fittings, provides the ultimate in flexibility. Plugs are included for unused ports.
- Unique Mounting Bracket Design allows for 360 degree adjustability. You can mount this catch can practically anywhere in your engine bay.
- Each kit includes two (2) 1/4" NPT elbow fittings and a 10" length of clear tubing, allowing you to make your own fluid level gauge.
