1 - 6 of 6 Posts
Eg Sedan
I have the issue of speedometer sitting at 5 when key is off. When key is turned on, it jumps to 30. Also odometer does not roll over.
I looked at the sensor and the black wire from the plug was pulled out of it. So, I stripped some of the plastic off until wire shown and shoved it back into the plug. Turned key, still at 30 mph so clearly this wasn't a fix. I did use simple green degreaser on the prongs of the plug in case of corrosion.
Any further suggestions?
98 Civic LX
check the fuse
1995 Honda Civic EX
you try replacing the VSS? they can be acquired decently cheap, and worth a shot, worst case scenario you have a back up one laying in your tool box for next time.
1 - 6 of 6 Posts
