Got some PHAT ass?
So I got the engine pulled out of my car and it's going to go to the machine shope on monday and I need to find out how much valve clearence I will have.
y8 head Jg85vt30 cam
y7 Block d16a6 pistons
I'd like to mill the head a little, what would be the most I could mill with this setup?
by using this comp calc http://www.knology.net/~jediklc/D.htm i figured your CR would be 10.85 running a y8/z6 headgasket. i would say that you will have pretty good clearance running this setup(at least +/- 5 degrees each way). of course the best way to figure it out would be to clay the motor. of course you are going to have less clearance the more you mill the head. i would say you should calculate how much you want to mill the head to achieve your desired CR and then clay the motor upon building it.
