when going from dpfi to mpfi on a dx, can i still use the pm5 ecu or does i need another ecu.
its just for starting up the engine.
one more q.
if i use the obd1 injectors, should i use the risister box. if no where should i connect the other wire that must go to the risister box. (not the signal wire!!!!)
one more q.
