CIVIC COUPE
hey im about to change some things up with how i did my vacuum lines. was wondering if i should use thread tape on the fittings for the vacuum manifold and on the turbo housing to keep from vacuum leaks?
what do you guys do?
thanks guys
95 ex coupe
even if it doesnt leak without the tape you should still use it.
Unless you're using AN fittings, always use thread sealing tape. If there is a possibility of it being exposed to fuel or oil, use the pink tape. I only use the pink tape for anything engine related just to be safe.
