since there is no nipple on the turbo Im hunting around for some places to tap in and hook up the BOV , Boost Gauge , and Wastegate
Does it matter where I tap in at?
I tapped the
BOV in front of the FPR
is this a good place for the wastegate to get vacuum?
from T-ing off this nipple on the PS pump?
vacuum
I tapped the
No, do not tap there as that is not a vacuum line. You can get an Eagle Vacuum Manifold and have everything go there or you can "T" off of your fuel pressure regulator vacuum, or brake booster vacuum lines.
top
Are you running an electronic boost controller? If not then you should know what psi spring is in there and leave that port open.
its got a 10 psi spring
the line you see hooked to the bottom port isnt run anywhere and is the line im tryin to find somewhere to TAP in
