1 - 2 of 2 Posts
J
i'am swapping dpfi->mpfi. i've taken the vacuum lines off to replace them with silicone ones but now i forgot how and where to route which one.
these two are the main problem.
i believe the upper goes to purge red hose
but i have no idea where the lower one goes
IM is D16A6
lower one is a coolant line.... the heater sources for IACV and Fast Idle Valve (one on TB.
Coolant should go in and out of both =)
I believe the line from the bottom goes to the water pump rail in the back of the engine.
1 - 2 of 2 Posts
