Can a go ahead and install my DSM blue top injectors when I do my DPFI->MPFI swap and use my SAFC to make them run like stock? I've been conviced to do a standalone when I actually put my turbo on.
Good lookin out bro, and you're local too!http://www.beesandgoats.com/boostfaq/g2icturbo.html#PCV
Scroll down the page in the middle, this site has a lot of good info to read up on :TU:
sounds about right. i used to run my setup around -45 to save on gas.yeah you just need to take out the right amount of fuel across the board. i believe it was some where around 43%. can someone correct me if i'm wrong.
Ah ok, gotchaif you're not turbod then i wouldnt put them in. you'll still run rich as hell and the afc wont really be able to correct that. to a point, yes it can but it cant de-tune an injector to something lesser it only controls how long the injector stays open. so it might only open for 10ms but its spraying 450cc's in that 10ms time period.
i dont know how long an injector actually stays open, im just using that as an example
