1 - 17 of 17 Posts
Hi mates. I rencently purchased a chipped P28 + Burn2 + Ostrich 2.0 and I would like to use my AEM UEGO as the OEM O2 sensor.
But the UEGO doesnt have the narrow band emulator (0-1v) it just has the 0-5v output. Is there any trick or something to to use it with my ECU without moddifing it (the ECU) as I read on MGPFI?
If I use the 0-5v output as ECU input... the readings will be right? I mean, if the datalog shows by exaple 14.0, will be that number right? what range of values can I read in that way?
Thanks.
the highest voltage the ecu can see with out modification to the ecu board is 3.5 volts. you will need to scale the afr to voltage. if you read the instruction manual that came with the uego, it tells you how to change the the voltage on the gauge so you can wire in the o2 sensor to the ecu.
This is what I found:
Configuring Calibration Outputs
The AEM default position is (P0). When set to (P0) (Figure 10A), the gauge displays AFR values. (P1) is the same as (P0), except the gauge displays lambda values. These settings (P1 and P0) implement a linear calibration with the most useful voltage range possible (0-5V). The AFR calibration (P2) is linear and similar to (P1) with a smaller voltage range (1-2V). The AFR calibration (P3) emulates the Autronic Wideband O2 Sensor calibration (0-1V). The AFR calibration (P4) emulates a non-linear Nernst Cell calibration (0-1V). Refer to the Table 3 and figure 9 for specific calibration details.
LED LED Lambda AFR (Gasoline) Analog Output Voltage Modes:
Number Color (λ) AFR LED "ON" Range P0 P1 P2 P3 P4
LED 1 Green 0.683 10 Rich Rich 0.000 0.000 1.000 0.000 0.905
LED 1 Green 0.700 10.25 Rich Rich 0.125 0.125 1.025 0.013 0.904
LED 1 Green 0.717 10.5 Rich Rich 0.250 0.250 1.050 0.025 0.903
LED 1 Green 0.734 10.75 Rich Rich 0.375 0.375 1.075 0.038 0.902
LED 1 Green 0.751 11.00 Rich 11.125 0.500 0.500 1.100 0.050 0.901
LED 2 Green 0.768 11.25 11.125 11.375 0.625 0.625 1.125 0.063 0.900
LED 3 Green 0.786 11.50 11.375 11.625 0.750 0.750 1.150 0.075 0.890
LED 4 Green 0.803 11.75 11.625 11.875 0.875 0.875 1.175 0.088 0.880
LED 5 Green 0.820 12.00 11.875 12.125 1.000 1.000 1.200 0.100 0.870
LED 6 Green 0.837 12.25 12.125 12.375 1.125 1.125 1.225 0.113 0.860
LED 7 Green 0.854 12.50 12.375 12.625 1.250 1.250 1.250 0.125 0.850
LED 8 Green 0.871 12.75 12.625 12.875 1.375 1.375 1.275 0.138 0.840
LED 9 Green 0.888 13.00 12.875 13.125 1.500 1.500 1.300 0.150 0.830
LED 10 Green 0.905 13.25 13.125 13.375 1.625 1.625 1.325 0.163 0.820
LED 11 Green 0.922 13.50 13.375 13.625 1.750 1.750 1.350 0.175 0.800
LED 12 Yellow 0.939 13.75 13.625 13.875 1.875 1.875 1.375 0.188 0.775
LED 13 Yellow 0.956 14.00 13.875 14.125 2.000 2.000 1.400 0.200 0.750
LED 14 Yellow 0.973 14.25 14.125 14.375 2.125 2.125 1.425 0.213 0.700
LED 15 Yellow 0.990 14.50 14.375 14.625 2.250 2.250 1.450 0.225 0.600
LED 16 Yellow 1.008 14.75 14.625 14.875 2.375 2.375 1.475 0.238 0.410
LED 17 Yellow 1.025 15.00 14.875 15.125 2.500 2.500 1.500 0.250 0.240
LED 18 Yellow 1.042 15.25 15.125 15.375 2.625 2.625 1.525 0.263 0.170
LED 19 Yellow 1.059 15.50 15.375 15.625 2.750 2.750 1.550 0.275 0.137
LED 20 Yellow 1.076 15.75 15.625 15.875 2.875 2.875 1.575 0.288 0.113
LED 21 Red 1.093 16.00 15.875 16.125 3.000 3.000 1.600 0.300 0.100
LED 22 Red 1.110 16.25 16.125 16.375 3.125 3.125 1.625 0.313 0.091
LED 23 Red 1.127 16.50 16.375 16.625 3.250 3.250 1.650 0.325 0.083
LED 24 Red 1.144 16.75 16.625 Lean 3.375 3.375 1.675 0.338 0.077
LED 24 Red 1.161 17.00 Lean Lean 3.500 3.500 1.700 0.350 0.076
LED 24 Red 1.178 17.25 Lean Lean 3.625 3.625 1.725 0.363 0.075
LED 24 Red 1.195 17.50 Lean Lean 3.750 3.750 1.750 0.375 0.074
LED 24 Red 1.212 17.75 Lean Lean 3.875 3.875 1.775 0.388 0.073
LED 24 Red 1.230 18.00 Lean Lean 4.000 4.000 1.800 0.400 0.072
LED 24 Red 1.247 18.25 Lean Lean 4.125 4.125 1.825 0.413 0.071
LED 24 Red 1.264 18.50 Lean Lean 4.250 4.250 1.850 0.425 0.070
I think if the ECU only reads from 0-3.5v , according this table , in P0-P1 mode I can read from 10-17 AFR wich is enough for datalogging and tuning, right?
honda/firebird form.
why would you want to use this as an oem o2 sensor..??? you dont have the aem guage??
yes but I have a dataloging cable solded in the ecu, so I do a datalogging now, Im using the narrow OEM O2 sensor, and this is a bad start for ECU tuning. In the other hand, if I replace the OEM for the AEM, I can datalog more accurate readings.
Anyways, The gauge is still working, because the 0-5v cable of the AEM comes from the gauge.
I have the LC1 wideband from Innovate which has a programmable narrowband output as well. The default setting is at the stoic setting so straight from the box I could use it as a narrowband in place of the OEM. In quickly reading through the AEM instructions it appears as though they only have the 0-5V output(wideband), so I don't think you can use it in place of the OEM sensor right out of the box. However, if you find a way to scale its output to 0-1V with 0.5V set to @ 14.7 AFR, I don't see why you couldn't do it. So my question is, do the instructions tell you how to program the output voltage for a specific AFR reading?
It's not totally clear to me what you're trying to do here but keep in mind that the WB and NB output signals are very very different. The WB has a linear signal that indicates an increase in AFR in proportion to an increase in voltage. The NB signal shows 1 volt until an AFR of 14.7 is hit then it quickly drops to 0v. This graph should help illustrate that.
One thing that's clear to me is that these signals can be very sensitive to outside interference so I wouldn't split the output from the sensor to a gauge and ECU at the same time. PLX recommends that noice filtering capacitors be added to theuir circuits and even Honda uses shielded wires in their OEM O2 wires.
Therefore, my recommendation is to use a WB that has a separate NB and WB output and use the NB for your ECU's closed loop operation and the WB for tuning, datalogging, or gauge display.
88 ED6
The AEM doesn't support NB output. But, that's how I had my LC-1 configured; although wideband output wasn't hooked up to anything as it already has RS232 output. For the AEM, you have to wire in your own RS232/DB9 connector.
If your header has two O2 bungs; use one for the OE O2 and use the other for wideband/tuning.
88 ED6
You can use that for input, but it'll still be useless for tuning; you lose accuracy.
btw, for my comment about AEM NB output; it can't do both*
well, then if I wanna use for tuning, what should I do?
(Im real noob on ecu tuning, I gonna tune with crome.)
I have a nokia cable for datalogging soldered to de ecu.
The AEM have 2 wires, one for datalogging (blue) and one for 0-5v output, so I should use one for dataloging and the other for ecu imput, right?
First: If I use a RS232 connector to dataloging the AEM BLUE Serial Output, does anyone have the schematics for wiring my AEM output cable to the connector? The WHITE (Nernst Emulation converted) cable shuold go to the ECU O2 pin, right?
Second: I dont know how to combine the AFR reading in the RS232 connector with the nokia dataloging cable. Because in crome the dataloging port is just ONE, and I need 2, one for AEM AFR and other for ecu parameters, right?
88 ED6
The manual should have the schematic; but IIRC you're just using 2 pins of the DB9 connector. Yes, the white would go to O2 input. The only thing I'm not sure is, if the programming changes the serial output. In other words, if it's set to "Nernst"; both serial and O2 signal would be 0-1v.
RS232 is serial. It would go to the serial port on the computer or a serial to USB adatper; but the program must be able to read off of two com ports.
Honestly, best method is to just modify the ECU to read 0-5v. I just realized, you'd be throwing a CEL for O2 heater anyways so might as well go in there and disable it.
88 ED6
I wonder why I didn't notice this: You can probably use P2 and just adjust the tables.
Or; just adjust the tables for wideband(the ECU will read to about 3.8v IIRC without modification)
1 - 17 of 17 Posts
