1 - 20 of 26 Posts
1999 civic Hatchback
Hello guys.
This post serves as an update for whats going on with the D15B2/B7 Rods.
We have 2 DSO Testers which are currently doing testing of the rods.
Here is a preliminary result of the fitting of the rods into the block.
Video 1: No Notching.. Shows clearance from rod to sleeve. Its a bit difficult to get exact measures as the feeler gauge is flat and the surface is round, and space tight to reach all the way in but clearance is approx 1mm to contact on each side.
View My Video
Video 2 : No Girdle notching. There is enough clearance from the rod bolt to the girdle. No notching will be required.. there's more than 2mm clearance.
View My Video
Video 3: Deck height piston position.
View My Video
Testers are currently finishing assembling the motors to actually start running the rods and boosting/tuning.
Thanks..
Boost Gets You Laid
Del Sol
Looks like another great product in the making :)
Can't wait to see what kind of numbers Honda's other little workhorse puts out
92 civic cx hatch
you just made all the d15 blocks that have gotten junked very happy and the d15 crowd +1
Are these tolerances going to be sufficient when the crankshaft is spinning 8K to 9K RPM's?
1+mm is plenty of room. 2mm might as well be a mile.
man i hope these come out soon. i have my block sitting here ready to be rebuild and im really trying to hold off until these rods come out!!!
1992 Civic Si
Fucking awesome.
Now we can turn any old D15 into a boost beast.
What would the compression look like with Vitaras + a VTEC head? Also are you doing standard length as well?
He said previously they are same length as jdm d15b rods, which I believe are 137mm. If that's the case, Zeal shows 7.67cr all else oem. z6 head bumps it to 8.10, y8 to 8.35.
94 Civic Hatch
sweet hopefully these come out by end of the summer so next year i can put alot of boost to the b7. this summer is gonna be a low boost small turbo setup, then if everything works out with these rods next summer will be bigger turbo high boost.
so with a b7 head my cr will be 7.67ish ?
That's what the calculator showed with vitaras and 137mm rods
With a standard D15 crank, they'll be out of the block on 137mm rods.
136mm rods would fit better.
Didn't even look at p2d. FML.
rods are not 137mm... They should be 136.40mm
Thanks for clarifying.
That puts all else oem cr at 7.37, 7.92 with vtec head. Looks good.
1 - 20 of 26 Posts
