I am going DPFI to MPFI from a D15B2 to a D16Z6 and its the wiring i am stuck on!!
Do i need a resistor box? If so from what engine/car? I don't need a conversion harness because it is already OBD1 as it is a 1994 car
PLEASE HELP
I have people travelling 200 miles tommorow to help :(
Chris
Just looked at my car and figured out it is definetly OBD-1
PROBLEM 1 SOLVED
PROBLEM 2
If i don't need a resistor box are the plugs just wired into the loom and connected into the ECU for it to control the injectors?
I have looked at a spare D15Z6 i have in my garden which is v-tec and the plugs which plug into the injectors just look as though they run straight into the loom without a box or anything? How are they controlled, do they just run into a loom connect to a plug then connect to the ECU?
