1 - 16 of 16 Posts
sorry should add they give 8.8:1 cr with a 3mm headgasket with a 43cc combustion chamber on a dohc zc
racist-bigot-sexist-homophob
Use feeler gauges to meaure the ringlands. They're not stamped anywhere on the inside?
they are definitly not factory pistons, would have been built in 2001 (last owner)
No stamps at all if they were pm3 they would have be stamped
so id say at a guess non dished gives aprox 9:1 cr on a stock headgasket like a stock motor but forged ? cant be out of a sohc as would give a way lower cr in the dohc
wheres my money man!!
No stamps at all
how do you know there not factory if you see no marks on them?
they look like a normal piston from like a b7 or a6
I had forged srp's out of an a6 in my dohc zc.
And I agree with cervan and sleepy...PM3's.
wouldnt they have pm3 stamped on them? and they all machined up awsome just like a srp
If they were OEM yes. The could be aftermarket cast PM3's, in which case they wouldn't be stamped.
97 honda coupe
if they are SRP's look for forged marks, if they are cast they are stock pm3 pistons trust me on this. And if they arent stock, they are aftermarket nippon or mahle pistons.
honda/firebird form.
the op should def be able to tell if they are forged or not... totally differnet looking material.
NO way those will give 8.8:1 compression in a DOHC ZC head.
Need better pics and the numbers off the pistons.
I got 8.6:1 with a dished SRP A6 piston (dish was smaller than stock) in my DOHC ZC and the comp height of the PM3 is higher + no dish of the Pm3 = he should be good to go.
1 - 16 of 16 Posts
