1 - 20 of 26 Posts
96 DX hatch
I have a z6 head that I'm cleaning up for my turbo build. I am going ahead and upgrading to supertech valves/springs/retainers and I'm keeping my eye out for a used cam. In the meantime I am going to leave the stock in and I was wondering if I can up the rev limit from stock or is a cam nessisary?
94' DX 2-Dr
you can but more than likely you wont be making any power revving that high and acceleration will probably be reduced..
del Sol si '94
You can rev higher now. No need to keep revving after the stock cam stops making power tho. But its fun lol
why up the rpm if its not making power there? you only need as much rpm as the engine want once it stops making power your done,
del Sol si '94
lol. He did say he is looking for a deal on a cam yet. Then its time to rev
formerly allnaturalrex
1989 honda crx si
rev it all you want you'll just be wasting more gas and not making any power.
del Sol si '94
Any suggestions on a good cam regrind for a boosted dd? Shooting for high 200s whp.
Delta seems to have a good price on boost cams
same
with an adjustable cam gear you can get a little more RPM out of the stock cam, but you REALLY need a dyno to get good results.
why change the cam though especially in a daily driven car, keep the stocker and maintain stock driveability and less tuning headache.
96 DX hatch
After much reading I am leaning toward a delta regrind. Either a 272 or a 260, I run a smaller turbo and am not looking for huge numbers so I will have to call and ask them for their suggestions. I figure for >$100 I may as well while I am swapping valves and springs. Skip the retainers and get the cam sounds like a good plan to me.
95 honda del sol Si
I hear retainers are still up in the air whether you need em or not. I'd say hook yourself up with a 272. heard good things about them and they are within most budgets
Ferio inspired
90' Civic sedan
i would def rev the stock cam. depends on your tune, but for sure the stock will run out of steam.
i raised mine to keep the RPM up between shifts so i wouldn't fall out of the power band. daily driving it obviously you wouldn't be revving that high so it shouldn't matter.
get the spring and reatiners and rev it! :bigok:
See above...
^Space bar still missing? LOL!
OP, I had a stock Z6 with all of the normal bolt-ons. Took it to the dyno, and what do you know...the car stopped making power at 7200, though with stock internals can easily net 7800-8k all day long.
The only reason I could see reving pass 7200 is for the unfortunate event that you have a VX/CX or DX trans. I had a VX for a while, and I rev'd it out to the top of 2nd netting 92mph! LOL
FF Misfit
Accord
You shouldn't even need a cam for your power goals however since you've already replaced the valvetrain the Delta 272 should be a good option. Depending upon your turbo size it can also help the response.
1 - 20 of 26 Posts
