1 - 10 of 10 Posts
91 Civic
anything will fit with enought fabbing? but why ditch an oem key setup? "Any vehicle with lock cylinder separated from the door handle" dont think it will just slip right into the handle.
88 civic hatchback
My driver door lock just spins when I put the key in, it locks but u can use a shaved key to unlock. Just want to be safe ya know. But ill probably just buy a new set of locks for the car
08 H-D Ultra Classic
I would either fix the problem with the lock you have or replace it with the factory style setup. Its probably just something simple causing it to just spin in the first place. Had you took the door panel off yet to see?
91 Civic
this^ and you can easly remove to lock cylinder and replace it with a new or junk yard one (re keying isnt that difficult ether).
88 civic hatchback
Haven't really check the lock out yet, been super busy with new job. I'll try this weekend and keep u guys posted. Hopefully its a simple fix. Thanks for the quick responses.
Two men shy of a group
99 civic sedan ex
1 - 10 of 10 Posts
