1 - 7 of 7 Posts
Hey D-Series.org! I am new to these forums. I know there are thousands of threads about Idle problems but I think I have a somewhat unique problem on my hands. I want to try to figure it out with you guys first before I take it to a mechanic.
So my car is all stock. Auto d16y8. On cold start the idle will be between 1500rpm - 2000rpm. But after a while of driving and I shut off the car but turn it on the idle sometimes goes to about 300rpm and it will stay there. So I bought a new IACV from Rockauto and now it will randomly shut off immediately after starting. The idle won't go down and the adjusting screw is all the way turned clockwise. Help?
bleed coolant? idle relearn? vacuum leak?
I dont hear any vacuum leaks but may be. I guess i should give bleeding the coolant a try. And how would i do an idle relearn?
92dx-turbo 92cx-pimp
the oring good on the iacv and gasket? check the port on the tb to the iacv on the outside of the butterfly there should be a small port hole to the iacv make sure its clear of debris, and check your throttle cable tention
Discussion Starter · #5 ·
The new iacv came with a new gasket. Ok i'll check the port hole. Throttle cable is a bit tight. Would that affect anything?
Adjust throttle cable so it has some flex before opening then adjust the base idle
Photo Credit: RonJ
1 - 7 of 7 Posts
