1 - 20 of 22 Posts
Hey everyone, so a couple months ago I bought an ebay harness from uneeksupply. Here's the link to it: ECU Conversion Jumper Harness OBD0 to OBD1 Fit Honda | eBay ... 1439.l2649
I'm trying to wire up everything on the subharness, and the item never came with instructions. I literally spent a couple hours tracing each wire to the pin location and labeling them, before I found this: https://uneeksupply.3dcartstores.com/as ... al%203.pdf their "instruction manual".
So my questions are
1. The power grounds, I can just hook them up to any ground on the chassis, right? I know this is a dumb question, just wanting to be safe.
2. The yellow wire that goes to D4 is for the Service Check Signal. That's perfectly understandable, but there's a wire spliced into it that goes to pin B20 on the obd0 side that's for the "ignition timing adjusting connector". Is it supposed to be like that? If so, from what I could gather I just leave that yellow wire disconnected and away from any grounds.
3. Since I'm going obd1, I have a 4-wire O2 sensor. The company's pinout diagram shows only wires for the O2, so I'm thinking the last wire I need is the one still on my original harness originally intended for the 1-wire O2. Is that correct?
P.S. My car is an 89 CRX DX converted to MPFI, with a d15b2/d16z6 mini me. I can take any pictures if necessary. These should be stupid easy things to answer, and I'm sure many of you have done something very similar, if not exactly the same. Any help would be greatly appreciated! :oops: :biggrin:
Pics of the power ground and where it comes from.
D4 is a ground for the cel. Only needs to be grounded when checking for codes or doing timing adjustments.
Pics of the o2 wires coming off the ecu plugs from the jumper harness,need to see what there are. And where there coming from to tell you what they are.
ministry of mayhem!
93 honda integra
next time get wiring from this guy ^^^^^ or Onatop.
Alright, I'll get pictures either later tonight or tomorrow. Thanks
Yeah, maybe if he didn't live clear across the country :p
Here's the pictures. Power grounds circled in black, O2 wires in red. In case my terrible pictures are giving you a headache, I'm going to write where each one pins into below to try making things easier.
Black= Pin A23 obd1 side (power ground) & pin A2 obd0 side (main relay/ground)
Pink= Pin B1 obd1 side (power ground) & pin A15 obd0 side (main relay)
White= Pin D14 obd1 side (primary O2)
Blue= Pin A6 obd1 side (primary O2 sensor heater control)
Red= Pin A25 obd1 side (ignition power source) & pin A13 obd0 side (main relay) <--- Pinouts I look at say ignition power source, but the company says it's the O2 power. Forgot to mention that on the first post. Seems like this one doesn't have anything to do with the O2, so either the company made a mistake in their manual, or I'm just wrong.
Thanks, Andrew
Oh, and ignore the messy room in the background :p
All the wires you need are there.
A23,24 & 26 are grounds for ecu and main relay.
A25 & B1 (pink) is a switched power source from main relay to ecu/o2 sensor. The 4 wire o2 sensor needs this power source for the heater part.
D14(white) is the o2 signal wire.
A6(blue) is o2 heater.
You should all so have a wire from d21 for the o2. It's the sensor ground from the ecu.
D4 is a ground for the cel. Only needs to be grounded when checking for codes or timing adjustments.
You will all so have two wires for VTec. These wires only need to be hooked up if you have a VTec ecu and head.
Hope this helps. Didn't notice the room till you said it.
B-series Destroyer
4g 4d civic
Thanks! I'll try to get everything wired up when I have free time and update the results. Repped.
I thought this was my thread from 2 years ago.
I did get mine figured out with 2jzdreamin's help.
Searching for thread.....
http://www.d-series.org/forums/engine-management/152393-anyone-ever-used-uneek-supply-ecu-jumper-harness.html?highlight=uneeksupply
Yeah I tried reading that exact thread before posting, but none of the colors were matching up and I was getting more confused haha. Kind of looks like uneeksupply used to use the same manual hamotorsports has on their website, which is why the colors were different
Ok something I can't figure out...
Above you said "A25 & B1 (pink) is a switched power source". But A25 is red for power source and B1 is pink for power ground. So it seems like A25 is for the power wire on the O2, but where does the B1 power ground go? Do I just ground it to chassis ground along with the other wires, or does it go to a certain location? Another thing I thought of doing was splicing A25 with B1 for the O2, but that sounds dumb and I don't want to ruin anything. Currently the wires A23, A26 and B2 are being grounded under the passenger side dash.
Ok some things I can't figure out...
Above you said A25 & B1 (pink) is a switched power source. A25 is red and B1
On the obd1 ecu plug b1 and a25 are both powers. I'm not going by colors,I'm going off of there location in the ecu plugs. The maker of the obd0 to obd1 jumper harness could have used random wire colors.
Ok I think I see what you're saying. I was looking around some more and found some pinouts that say B1 goes to A25 and A25 is *to main relay and to ground for o2*. So if they're both a switched power for the O2 like you said before, should I splice B1 with A25 then wire up the O2 sensor accordingly? I should have everything else figured out on the subharness by now, just not sure what to do with B1.
you shouldn't have to splice anything,it should all ready be done in the jumper harness...
can you post a full pics of the jumper harness and the sub harness?
They should in the obd-0 ecu wiring.
Discussion Starter #16
Really? In the OBD0 side one goes to A13 and the other to A15. They don't connect or splice into eachother in any way at all, as shown in the first 3 pics on post 5. They both go to the main relay, but I still don't know what to do with the OBD1 B1/OBD0 A15 wire that is currently sitting unconnected. Some places say it's a power ground, you and other places say it's a power source, some say it goes to the A25 OBD1 side. So it seems I either combine it with the A25 wire, or ground it. And I don't want to accidentally fry something if I do the wrong thing.
Rico58204, what did you end up doing with that pink wire? I'm honestly thinking of getting a Rywire or Boomslang harness at this point.
Post pics of the full jumper harness so I can see it better.
You don't need to do any thing with the pink or red wires at the ecu plugs. There for the o2 sensor and the iab(gsr).
4 wire O2 sensor wiring is
Power=red a25 or pink b1
Signal white d14
Sensor ground d21
Heater wire a6 blue
VTec wiring
A4 and d6 not sure on the wire colors as I can't see them
Knock sensor wire
D3. Looks to be the orange wire. Not needed.
The wires i didn't list is cause I can't see them. I don't want to tell you the wrong thing. All so some of the wires are not needed.
Discussion Starter #20
Oh wait, so with A25 & B1, I just use one or the other for the O2 power?
A17 D3 & D4 (IAB, KS, SCS) are tucked away unused. Everything else is currently hooked up properly so I didn't try getting them in the picture. I guess whichever I don't use on the O2, I just tuck away? Sorry you had to explain things multiple times, that B1 wire was just kicking my ass
1 - 20 of 22 Posts
