1 - 13 of 13 Posts
Hi
Unfortunately I was forced to rebuild my engine due to bad head gasket :mad:
My plan:
-D16Z2 engine (same as D16A6)
-0,6mm (0,023in) gasket
-1,2mm ( 0,048 ) head milling
-d16z6 4-2-1 exhaust manifold
-2inch exhaust (2 mufflers)
-homemade adjustable cam gear
-60something mm throttle body
-CAI homemade
-port&polished head
Compression should be around 10,8:1. I'll be running on 95oct petrol.
Questions: :)
I've read that milling retards the camshaft. Should I advance 4 degrees to get it to 0*?
What else would you recommend me to buy/tune?
What CHP and WHP should I expect?
TIA
Konik
man i thought i was building on a budget, "homemade adjustable cam gear" never heard of that one. i hope that you're as ingenious as you are crazy! but seriously keep us posted man and good luck!
This is as close to homemade as you can get. THis was made in the early 90's way before anyone was making aluminum c/g's. Made from the facotry gear actually. inside was machined out and new piece was machined to fit inside..
Sth like this I think. cam gear and throttle body are not for 100% because of $$$.
Any answers to my queestions?
n2o is cheap.
I have sparyed everything I have ever owned plus a few rents.
You see where I'm from Dibble?
N20 is NOT cheap in here + there's no fun for me to have power for a few seconds...
Certified O.G.
A Shitbox
Nearly four year old thread, really?
Facepalm.
same
if your getting a cam gear why not get a camshaft too? and i would say about 110whp for what you have listed
And it's his first post too! Not a good way to start out posting on a 4 year old thread. TRIPLE FACEPALM!!!!!
1 - 13 of 13 Posts
