1 - 20 of 44 Posts
Lifetime Awesome Member
'89 CRX HF
well ive been noticing my car seems to be missing a low rpm, usually when im taking off and theres a good load on the car. well today i was cruising and smoke started coming out of my vents. i immediately shut the car down and popped the hood. no smoke or anything, overflow was at a good level...
but i noticed that the breather on the VC was spewing a lot more oil than usual, and when i pulled the oil fill cap off there was smoke coming from under the VC. i checked the oil level and it seemed fine, didnt look diluted or anything. i get the feeling i may have cracked a ringland or im having HG issues. anyone have any insight on this?
after i restarted my car, i got on it hard to see if there was any smoke from the tailpipe, and there was quite a bit of blue smoke. obviously im burning oil, im thinking my motor doesnt like me much right now...
I
95 Civic coupe
'89 CRX HF
9295EJ-t said:
i think you are experiencing some pre detonation! sucks... it'll prolly last another month or so on casual driving.. you might have lost a piece of one of your pistons...
it happens in vacuum though, and usually when im not even hard on the throttle. i think its past the point of pre-detonation. most likely going to pull the head this weekend and find out for sure
'89 CRX HF
9295EJ-t said:
well.. i had this problem, and it turned out to be a melted piston...
i hope it isnt this bad for you....
haha, i hope not either. mine only sounds like a subbie at low rpms. other than that it sounds just fine. its just not it started smoking...
I
95 Civic coupe
boxer motor noises, coming from a honda=baaaaaaaaaad! ha ha.. ya... you lost a piston... you might wanna check you injectors as well.. but i wouldnt count on it being that... you are prolly gonna need a new motor...
no rebuild??
LMK throw a motor together for ya!
I
95 Civic coupe
you might be able to rebuild it, but chances are, if it detonated, there is damage to the cylinder wall..
check your spark plugs.. the misfiring problem COULD be an ignition problem, or fuel flow related problem..
when my injectors decided to take a poo, it sounded like a boxer until 3000rpm..
my motor sounded like that when I melted a piston as well!
Don't drive it!
you will tear up your cyl walls and rebuilding it will be tougher.
just do a compression test, that should be good enough to tell you..
you probably wont even need a leakdown.
'89 CRX HF
Discussion Starter #19
ehh, im gonna pull the head this weekend just to check it out. like i said, good thing i didnt sell that sohc zc. it will be going in along with my z6 IM and GSR TB :TU:
1 - 20 of 44 Posts
