So lastnight I was driving like an arsehole on the snow coverec side streets. I pulled off of one snowy street and onto a main road that was clear. The tires were spinning a bit and when it hit dry pavement something let go. I figured it was the inner spline on the left side cause the axel popped out and leaked some oil out. No big deal because in true Honda drag racer fashion I have 5 sets of spare axels.
Further inspection this morning revealed that the driveshaft was fine and the spider gear inside the tranny let go. (GAY) I have a spare tranny but it is in pieces because I welded the spiders together on it and just never got around to put it back together. My only option is I guess to put the other one together or just swap final drives.
What I wanted to know is that I read that a jdm ZC tranny has a shorter final drive ratio than a USDM Si tranny. Will it fit or does it use different axels. My buddy needs a tranny for his H so we have to go down to Toronto and pick one up. I was wondering if it was worth picking up the ZC one. I am not to sure but is the code on it XSI or something to that effect? Just wondering?
