Two step relies entirely on an external input, or some kind of configured threshold against other pre-existing inputs like Vehicle Speed Sensor or TPS.
Knowing the type of tuning solution you have would be a big start. Could you remove the top cover from the ECU, take a picture and post it so we can see?
You say its a "chipped" P06, but are you running ONLY a premade burned chip, or do you have an emulator solution installed in place of the EEPROM like a Hondata S300 or a Demon 2, etc?
If you only have a burned/tuned EEPROM installed, then you have no real-time tuning solution, and will need to consult a tuner who has the ability and equipment to read your chip configuration to see how two step is configured, then troubleshoot from there.
Otherwise, if you have a Hondata or Demon2 installed, use a laptop with their appropriate software, connect to the emulator board, and download the configuration to view it. Those hardware solutions and their software have menus that cater to 2-step, and all the details of what is being looked at to enable 2-step will appear in those menu's.
