1 - 4 of 4 Posts
If I buy a ecu chipped with Uber already and I want to re-tune it how can I do this? Is it a cable that goes from ECU to my laptop?
Also if Iam running atest pipe and switch to ob1 (which doesnt require a o2 sensor at the cat) will my emission test still work?
no cat, you will fail... definitely. also, many states will require you to have the obd2 dataport if that's what your car came with, so converting to obd1 will cause a failure, too.
you need a burner to change the programming on a chip. Search for willem burner on ebay.
1 - 4 of 4 Posts
