1 - 20 of 32 Posts
i was wondering who on DSO is running a 2.5" or smaller exhaust on your boosted engines. im curious to see the usual output with 2.5" or smaller exhaust on a small turbo d16
1992 Civic Si
This was last summer's build.
A6 block, Z6 head, FJ rods, Vitara Pistons, GT2860RS at 15 psi, tuned on crome. 267whp, 222ftlbs.
1992 Civic Si
Oh yeah and the exhaust was a clusterfuck kinda. 3" downpipe, 2.5" from downpipe to axle, 2.25" axleback.
1999 Civic hatch
I made 230whp on a stock D16Y8 w/ .63 eGay set up on 11 psi with a 2.25" down pipe and a 2.25" exhaust.
Tuner said exhaust wasnt choking it.
On a stock bottom end build? ~200 hp?
At low power I doubt you would see any noticeable power gain between 2.5 and 3" exhaust, although they would be an improvement of spool.
At 300+ hp it would be a waste not to run 3" exhaust (maybe keep the DP 2.5" if youre keeping AC)
1992 Civic Si
Pretty much. On a stock build keep it smaller, keep it quieter. On a built engine shooting for numbers go 3".
Im running 2.5" right now on the stock bottom end around 220whp; engine is coming out tomorrow night to get rebuilt and im keeping to 2.5" but I have a cutout for the track
i have a 60mm Apexi N1,cat converter with a gt2860r and made 330hp at 22psi...the exhaust setup is probably killing it...thinking to go up to a straight 3" exhaust system but still dont have the money!!!
del Sol si '94
r or rs? seems like alot for a r.
ok cool, i was planning on 2.25" catback with itr muffler on a z6/greddy 15g. glad it wont kill the little bit of power im planning on
1999 Civic hatch
Nice. with stock clutch?
Yes on stock clutch. :yes: Exedy OEM spec with about 15k.
No, stock clutch is piss weak. It's only good for about 140 ft lbs.
It held the 190wtq+ I threw at it just fine for about 9 months and it chirped 3rd.
Not completely disagreeing with you though, I couldve chirped 4th if I had a stiffer clutch.
1 - 20 of 32 Posts
