1 - 20 of 21 Posts
T
Ive searched all day now and cannot find any information that is written in common english for the beginner with no previous knowledge
Im basically just about to start my car and get it running and then tune it. Its an OBDO Crx with a D16a6. Im buying a chipped ecu that zenocron chipped with a basemap for my motor with a 1bar map sensor.
All the info i could find was just on making that basemap and it was still very difficult to understand.
The info guides and walkthroughs im looking for are about after you get the car started. If there are codes what they mean and how you figure them out and what will need to be changed in your program.
The instruments I have are
-laptop, dell something pIII with cd rom and usb port, should handle everything good
-wideband digital display sensor (will this work with turboedit and some sort of datalogging?). Im assuming I need some shit to do datalogging
-Moates Burn1 chip burner bought from Moates.net
-Do I need many spare chips?
We need information on like our first drive, we go around the block and wtf do we do? What am I supposed to watch on my pc if anything at all or do I do that after I go through soem gears? Just 1 gear at a time tuning?, I have to do this all alone 100%
Idle, Partial Throttle Tuning, Wide Open
We need to know how to play with things and the little tricks to make everything easier and safer, things to help make the best adjustments and calculations possible.
My basemap comes with a 1bar map setting, I need to install a 3bar, what do I have to change? Everything? DO I do this after ive started and finished all my fuel and ignition settings?
I dont know when I have pushed my engine to far, this is my first boosted car, I dont know wtf the wastegate is gonnaa sound like or a compressor surge or pinging. What did I do wrong?
I really dont know what to ask because I dont have the car running but I dont want to learn this when the cars running and just has to sit there.
While I was searching, turboedit seems to be the least followed and used of the rom editors and has the least technical backing and 500+ people making threads like these daily, TurboEF8 or xenocron or someone that knows what they are talking about should make a walkthrough, a complete guide. I guarantee people will donate money. make people pay for it if you fucking want. I'll donate money asap right away.
I AM WILLING TO PAY SOMEONE FOR A BEAUTIFULLY DETAILED WRITE UP. MAKE IT FOR EVERYONE, EXPLAIN MOST OR ALL OF THE THINGS IVE TALKED ABOUT IN GOOD DETAIL AND I WILL PAYPAL YOU $50
Ok, here you go... read the Wiki at http://pgmfi.org
Then go to the forums and read up on the software you want to use for your application.
Extra chips are good.... I suggest an ostrich as I own one.... it makes it alot faster.
To start off, you should make sure your car has a steady AFR at first start-up and idle...... once you get it right if the afr's are off, you need to drive the car.... logging whats going on. You basically want to start by driving the car (open loop) and logging AFR's at all RPM's to about 3500... speeding up and slowing down.... if the AFR's are too low, stop and reburn, try again.... get it nice and steady, then advance 1,000-1,500 rpm's obtaining a steady AFR. It could take time, but once everything is good and consistant at the rpm ranges, start by adding maybe 2lbs of boost at a time.... correcting AFR's as you go. This is why u got the datalogger... to retrace the maps, and add fuel where u need it.
Don't forget to set about a 1 deg retard per lb of boodt to start... once u get a good tune, you can decrease to .75 deg, and maybe less if u can tune it right.
There are alot of people here, and alot of info on tuning on the wiki and pgmfi.org. Everyone here is cool, and would gladly help you.... somtimes it takes a bit, but you normally get a quick response.
If u need help you can catch me on AIM or Y!.... I have been doing tuning research for the last 2 years now.... and am walking the path myself.
Welcome aboard!
T
Thanks so far guys
I dont expect individual members to try an answer my questions, they are way to great and unknowledgable questions to even answer.
I really was hoping there was a walkthrough or something to learn on and make my mistakes before I transferred them to my car
THings I could learn totroubleshoot and make my first tuning experience a good one and not a $1500 blown motor horror story and feeling of utter failure
ANy help and info in this thread will be heavy read by me and Im sure many members
Thanks
Yeah, right. Like your actually going to give anyone any money............. NOOBS.......... Clearly you haven't searched, because I know how to tune car's and I don't even have a turbo on my car. All this info has been covered a million times. It's not that hard, download and a rom editor and fuck around with it and you'll understand A LOT of it, just by looking at it.
91 sedan
so were NOOBS because we dont understand it? i read it up and down and still dont get it and i dont want to fuck up this engine that i put some money into. but i guess were noobs.
?? Ok........ What? What the hell is so hard about increasing the fuel maps to get the proper A/F ratio via a WBO2? What are you from Georgia or something :rolleyes:
The H Badge is it!
91 crx
for turbo edit???? ok open 2 TE editors, then in one of them open the stock pm6 map, or whatever ecu you're using. then open NG55.bin in the 2nd one, there are also ng60, ng58, etc.. open one of em in the 2nd TE...
copy and paste the maps from the stock pm6 to the NG(whatever)
then in the one u pasted on go to file > properties, select single map, then dual map again, go thru the selections below and fuck with it.. then click ok, or apply for some things
*sigh* sohc rules....if you just copy and paste the maps as you said thats really not going to work...map scalers are diffrent so therefore your putting the fuel values for instance that are read at 26inhg into a 31inhg column...obviously not going to run 100% interpolating the cells is a bit better...
check out xenocron.com and grab his basemap helper that has the maps already setup pretty much and interpolated.
edit: i just read that and it sounded kind of dickish so please dont be offended
if for some reason you read and read and u still dont understand it how fast are you going to learn from someone else post? every car is diffrent even if they all have the same parts thats just how things are in life.. not dont flame me or anything but have your the OP made a base map with boost option? once you make that you should be able to start the car up and drive it WITHOUT BOOST...
Turboedit has a "Auto-Detection of Fuel Multipliers " so it should be easy to get the car running...after that u just need to tune the fuelmap to get your target AFR...sound easy? hope so.. with Freeware like Turboedit/Crome/Uber most if not all tuning shop wont tune it so u have to learn it foryourself.
did you read my sticky?? it's a decent basics of what turboedit does for you. then you can go on to the more advanced stuff...
D
Discussion Starter #18
If you pick up an emulator there is Real Time Programing that could really simplify things. If you were obd1 crome has an autotune function that is supposed to work good. Ostrich is the way to go. If you are that nervous then read, purchase all your tuning stuff, then go to a dyno and have them use your setup, at my machine shop they dont chip or even tune hondata they need to use my stuff. I read for about three months before it "all" made some sense and then when I got in my car it fell together 'cause I had done my homework. Stick with it.
i can put it best like i did before...
READ THE WIKI! http://www.pgmfi.org
It will lead you right into the path of success.
The H Badge is it!
91 crx
ok so then why does it work when i copy the stock pm6 fuel/ign maps to ng60 and the fuel values are the same untill i look at the boost portion?
i think you're off ur rocker son...
either way u can export the maps then import them onto the ng60.bin... this is how the xenocron basemap writeup for making a basemap does it, and this is how everyone else does it.
1 - 20 of 21 Posts
