Dude I didn't understand you....to answer is probably not going to work, most gasoline engines will not produce enough exhaust gas flow to spool a turbo from a diesel engine (hence why they are on diesels)i don´t understand you.. If you can help me i apreciate.
if I am asking help it is because I do not know. because one knew it was not coming for here.
now do not come that it is they are armed in clever and do not help cromos..
uhh....a ton of .42/.48 came off diesels...yea usually the hot side on diesel engines is like 1.05 A/R, sometimes bigger. definitley not gonna spool on a honda. .48 or .63 is where its at![]()
yea the little 4 cylinder diesels.... he didnt specify what it was coming off of so no need to jump my shit....uhh....a ton of .42/.48 came off diesels...
knowing the size of the snail helps a lot
yes.Can i put a diesel turbocharger on a gasoline egine ?
