So two seperate ECUs?
So what are you gonna do if ones spinning redline from losing traction and the other is still pulling at like 5k...?
/QUOTE]
Traction control, but honestly that point is so far down the road that I haven't gone into much detail about how to do it. I'll probably borrow a system from some car that's relatively similar in terms of weight, wheel/tire size, wheelbase, etc.
Initially it will just be a rear engine setup. Once I get all the kinks worked out with that I'll start on the twin engine setup. It will probably mean re-designing/fabricating some stuff but I think starting with just a rear engine setup is going to be easier.honestly i say just get the engine in the back and turbo that. i feel like it would be alot less complicated.
but it's your dream and the 2 engine would be sweet!
I will definitely be cleaning my welds better in the future, especially when I start welding stuff in permanently. I talked about it with some FSAE guys and while 4 wheel steering would be awesome but I'm not gonna try it on this build.This is forking amazing; and clean off weld areas when you can. You'll get stronger welds/better penetration (heh) and less porosity in the weld itself. I mean "grind away paint/crap before welding" is all.
Otherwise... kick ass! Are you going to have 4-wheel steer? I don't recall seeing a post about it... but I know older Preludes had 4WS in the late 80s and 90s; but the rear only turned a few degrees, nothing over 10* I think.
Carry on!
Cool rickshawRolling out the donor car
